wiggall
- 151
- 43
- Lenore, Id.
Does anyone know of a source for 24 volt Christmas light strings? We would like to decorate THE BEAUTIFUL BEAST for the Christmas Parade this year
That is so..........redneck.We would like to decorate THE BEAUTIFUL BEAST for the Christmas Parade this year
If you bought one for some other purpose that would work quite well, except that it isn't a good idea to put a load on one battery only.Do what Carl says. Just get a cheap 12vdc inverter and hook it up to one of the batteries. Easy peasy, lemon squeezy.
Have you ever tried this with LED lights? I've read LED require an extra diode to keep everything "flowing" the right way. I thought LED might be cooler and use less power. I'm attending a Christmas parade and have been asked to use lights to outline the truck. I've thought about inverters but this sound better to me.Decades ago I put Christmas lights on a 12 volt Volkswagen. It isn’t very difficult and it will be even easier on a 24 volt system.
If you take a 50 bulb 120 volt AC string and measure the voltage across a single bulb you will find out that because of voltage drop each light will have (120 / 50) volts across it, in other words 2.4 volts. If you cut up a light string into 10 bulbs strings (24 / 2.4), and apply 24 volts DC across them you will get approximately the same intensity.
Now to turn theory into practice, I apologize for not having a drawing package, but I will try to describe it in simple terms.
You take some “zip cord” (bulk AC 2 connector wire) or larger speaker wire and run it around where you want the lights. One wire will be connected (preferably by a 10 amp fuse and a switch) to the positive side of your positive battery and the other wire will be connected to ground. Strip 1/4 inch of the ends of each string.
Start on the ground wire where you want your lights to start and strip 1/4 inch (don’t cut), connect (wrap the wire of the light string around the exposed section of the power wire and solder) one end of the first string and wrap it with tape. Stretch out the string and strip 1/4 inch of the positive wire 1/2 inch short of where the string ends. Connect the end of your first string AND connect the start of the next string. Stretch that string out and then strip 1/4 inch of the ground wire 1/2 inch short of where the string ends. Connect the end of the second string AND connect the start of your third string. Wrap it with tape. Keep doing this until you are finished.
The fuse is important because these lights were not designed for outdoor use and can easily short out if they get wet.
Take pictures.
Arlyn
