Like the top says the generator starts and runs great for 30 minutes, dies and will not start again for 30 minutes, but starts quickly again and again.
The 1965 era military generator is a 3.5kw that was given to me buy a friend we helped move into a nursing home three years ago. It's electric start and mounted on a small trailer.
I set it up at a little house on our property when we built a larger home to retire in. It's too small to run the new house but perfect for the little house we retired in.
I wired it into the little house with a outside switch to disconnect from the power company service. I did this two years ago. I thought I had everything ready for a power outage and hurricane Laura hit us three days ago here in South Louisiana
As expected the storm knocked out the power service, so we went to say in the little house powered by the military generator. It started fine and ran great for 30 minutes and died. I found thru trial and error, if I wait 30 minutes it will restart and run for another 30 minutes, over and over again.
I thick it might be the Coil getting hot and cooling down, but I don't know for sure since it's not my knowledge.
Does anyone have a clue on the repeat problem? It's not fuel supply because it runs so smoothly when it does run.
Please help me fine the reason why,
