Efituned
- 9
- 8
- Midland, Ga
A little history about the truck. I bought it a year ago with 18k miles in great running condition. I got tired of driving 45mph in the truck and needed an engine that could handle more revs with out changing rear end gears.
I got the engine from a friend that used it in a mud truck powered by propane. There is nothing special about the engine other than a Comp Cam 270h with roller rockers. I installed a Edelbrock 1406.
The engine cranks and idles perfect, but has no power under load. For instance if you try to power brake the truck with the pedal to the floor I will not spin the tires.
I did a cranking compression test and got 165psi on all cylinders. I replaced the distributor and I have tried about every different ignition timing position. I have another friend with a cucv and a worn out 350 that will smoke the tires and has great power.
What could be the problem?
