Enquiring minds want to know. I need this so I can put it in the 2018 budget.
here you guys go!
bought a freshly rebuilt trans that had 1000 miles on it for $600,
TCI controller for $550
TCI - TSP for $150
drive shaft work $310
since I was too much to do this in my drive way I paid a guy who has a shop with a lift and all the cool guy tools $800 - he let me help and it took us about 15 hours to complete the task.
total was $2410
the Gear vender option was initially high but became very reasonable as my project when further down the road and would be something I could do in an afternoon at home. Only down fall would be no overdrive in 4 wheel.
All things considered I am very happy with the results. I was initially thinking of getting all the OEM controller stuff from a salvage yard but thought better to get new electronics
I had one other item come up- with the new trans in place I developed a vibration in the driveline @ 58 - 62 mph- I adjusted the drive line angle down about 1+1/4 inches- utilizing the mounting bolt spacers that were initially above the frame where the rear cross member mounts to be between the frame and cross member which remedied the vibration- I do not see anyone lese who did the same swap have the same problem which makes me think I need to check my engine mounts.
let me know if you have any other questions- happy to help.
I forgot one other thing in the line of costs - $50 to a machine shop to make the adapter plate accept the new trans-
pete
