4 wheel steering on a 5 ton???
CDN-CUCV
Republic of Vancouver Island
I went and had a look at two M812A1's the other day and between the two, one could build a nice truck.
Anyway, considering that one would have access to two front ends, I thought four wheel steering would be an interesting adaptation to a bobbed 5 ton, 16.00 x 20R's etc...
Has anyone here done this, or attempted to? Any thoughts would be appreciated!
DUECE-COUPE
Scurry. Tx
sounds cool, but I don't think the power steering pump has enough power to operate both front assist, and rear hydrolic steering systems.
ROB L3
jefferson ohio
i have considered doing that to my bobbed 5 ton.i just havent come accross a doner 5 ton yet. i would use the front springs and hangers on the rear and use an electric over hydralic pump to run a double acting cyl mounted to the rear axle.you can also install a self centering valve to always center the rear steering when you let go of the switch.this is how the monster trucks do it and it works well.
CDN-CUCV
I was thinking the whole hydraulic system would have to be upgraded to make the set-up work forsure. I like the idea of having a knuckle-boom as well so I would need to install a system that could handle it all.
CDN-CUCV
That was my next step, to check the monster truckers tech on how the run their rear-steer.
Now this was the other idea. Having dual cylinders, front and rear, which operate in tandem or independently of each other. The idea is to, providing the wheel base is correct, to have a 0 degree turning radius. I live in an area where it would be advantageous to have a truck that could turn around in tight spots.
355
12
New Enterprise Pa
very expensive and no longer street legal with hyd front steering.also hyd rear steer must have lock to be street legal.
This is a big miscconeption. There is no law that says it's illegal or legal so it's more up to the preferene of the owner. Some deem it not safe but all the newer farm tractors are full hydraulic and with the newer transmissions can run in excess of 45 to 50 mph. If the system is not setup properly it can be twitchy and dangerous, so if your gonna do it don't skimp on the proper parts. It isn't illegal now, so no reason to give them a reason.
Nooner
Round Rock, TX
True about the 'not being legal' part, no mechanical link, but for off-highway use it could be fine.
Yup - Texas laws only care about lash.
Back to the PO's question - isn't most of the monster truck stuff 12v? I know a lot of the rockcrawler stuff uses an electric pump for the rear only.
I thought about putting rear steer on my deuce too, but until I can steer the front well I probably shouldn't look to steer the rear!
yeager1
Colorado
A 4 wheel steer bobbed 5 ton could sure make a great snow plow truck. Can be very safe if done right, a rear lock out should be used for road use. FYI- Some of the street legal Oshkosh plow trucks have it, might be a good place to start for ideas.
Condec
Port Alberni BC Canada
I hope you buy them cause I could sure use some of your residue parts. He is stuck with them and next phone call will be to scrap guy. Buy them and take the fire tanks off and sell them to said scrap guy. Let me know
deuce_09
san antonio/TX.
if it were me,in my opinion, i would just use the stock power steering for the front axle and use hydro steering in the rear and control it by a switch since u wont be using it as much as the front.
thats how most rock crawlers are.they only use rear steer when they need to get out of a tight spot. in mud trucks 4ws isnt used allllllll the time. most the time they'll use it to do a donut(which a five ton really cant,more like just turning slowly in a circle)or if they get stuck they use it to crawl out of theyre own ruts.
mike
jesusgatos
on the road - in CA right now
If any of you guys want to read about hydro steering setups, forget the monster truck stuff - just go to pirate4x4.com. Lots of rock crawlers are running rear-steering rockwells, and you'll find a bunch of helpful information there.
Wrench Wench
Indiana
How is the steering managed in an 8x8x4 like the HEMMT? Surely you're not going to tell me it's a mechanical linkage to both steer axles. I'd imagine it's a full hydraulic steer with a speed-sensing proportioning valve to cut down the amount of steer to the number two axle.
Thing I've never been able to picture about a full hydraulic steer is how to effect ackerman. If it's two separate rams, one to each wheel on an axle, then sure, it's be easy, but the valving would be a female dog. Independent rams would also be the only way to get a true 0⁰ turning radius. You were joking about that, right, OP?
Multiple rams per axle would just make me jittery. Additional complexity begging Murphy to ride shotgun.
Flat Black
9
Georgia state
no need to run multiple rams per axle... either run a double ended cylinder or run a single ended cylinder with a tie rod.
Read pirate or any other big off road board, there are tens of thousands of rigs around the country using rear steer and has been for years. Its very simple to do, its not scary and its controlled by a small joystick (usually) or something similar in the passenger compartment.
You can use everything from an AGR Rock Ram, to redneck steering (surplus ram or tractor parts) to PSC or POS (Station/Sean on pirate). The higher you go up the chain, the more expensive the parts get.
There are bolt on kits for Rockwells to be used as rear steer its been done so many times, there is nothing to figure out anymore...
