My little 1.5k set worked for a while, until the float started sticking (rubbery fueltank sealer) with a few simple steps. Running on a new boat gas tank, w/ new hose & priming bulb.
Open fuel valve, set fuel lever to correct position. Squeeze priming bulb until I see activity in the filter bowl, flip fuel-pump lever 10x, set choke full on (mine vibrates to half-choke as soon as the engine starts), check position of 'run' switch, wrap and pull.
Started first try every time for a week- then the rubbery coating on the float stuck to the inside of the bowl, and caused the pump to dump fuel out the air filter.
With my spare engine & carb, I'm looking hard at conversion to propane- this will eventually be mounted on a camper build.
