4L80E locked in second gear
mojo2013
Kansas City
I recently acquired an M1123 with a rebuilt GM transmission dated 9/10.
Truck originally shifted fine but is now struck in safe mode-second gear.
Fluid is in good shape, connections are together. Speedo is off by about 10mph (faster) than actual. Transfer case works well.
Any suggestions on where to start?
papakb
1,184
San Jose, Ca
Check the relay that provides +12v to the transmission control unit as a start. If you lose it the truck goes into limp mode. After that it's all the usual suspects.
AAVP7
261
Dortmund, Germany
Did you read out trouble codes from the transmission ?
As said above, there´s an amazing 4L80 troubleshooting manual out there, which is a very detailed reference and includes step-by-step instructions.
The tranny might default to safe mode if one of several sensors gives unplausible results. The manual will guide you how check them all.
