5 ton air lockers?
deuceman51
10
Scotland South Dakota
I've read tons of threads on the detroit lockers, but has anybody found anyone who makes air lockers for the 5t M809 axles? I am in the process of working on a M813 that was converted for powerline use as a digger truck/polesetter and my customer wants lockers added to it. From what I read, the detroits sound pretty dangerous to untrained operators. There is no way the average powerline guys will know to let up on the throttle when turning and I can't have a truck with 16.00x20s losing control and killing someone. Cost is not an issue with the company. I would prefer air lockers, but I guess I want to know just how well the detroits are working for everyone. I'm a little concerned about the tires getting chewed up like some guys report and the added 16.00x20s(which I hate to begin with) are probably more likely to snap an axle if the rears keep locking up on their own.
Fire away!!!!!!!
wehring
26
Angleton, TX
Factory airlockers
I have two sets of FACTORY Rockwell airlocking axles that fit our 5 tons. An added plus... the shafts are 1/4" bigger than the 800 series axles.
Justin Wehring
979 997 3112
fastfreddy
Conservativeville Michigan
Can anyone take a educated guess at how much it would cost to have the air lockers installed on a 900 series 5 ton? and would the air system on the truck be enough or would it need it's own dedicated system to operate the lockers and would the lockers that come on the truck work with the air locker system? sorry I'm not trying to hijack the thread just expanding on the OP's questions.
Floridianson
2,501
Interlachen Fl.
Justin Wehring
979 997 3112
Im guessing the locking axles are for the rear. Could it be taken out and put in the front stearing axle?
4,793
Yes but sometimes you need it.[thumbzup]
Agreed! It just can be "fun" at times. A selectable locker is the ONLY way to go when it comes to a front axle IMHO. ;)
I don't think I'd want a locked front axle in a deuce without power steering though. :deadhorse:
wehring
26
Angleton, TX
steer and rears
These are a full set of 3 with air lockers. You can change out the backing plate with 900 series parts to convert them to 900 style brakes. Yes the 900 air system will operate the air locking mechanism.
I can provide you with just the axles or do a complete conversion to your truck.
Justin Wehring
979 997 3112
DUG
Senior Chief/Moderator
73
Mesquite, NV
How well would a truck drive with a standard (non air) locker in front and locking hubs in the unlocked position?
4,793
As well as an open front diff axle with drive flanges on it. Although 5 ton hubs are crazy expensive...
DUG
73
Mesquite, NV
I wanted to know for my deuce, but saw no reason to start a new thread.
I'm wondering if a standard locker with locking hubs would be better than an air locker.
I also want lockers in both rears with one of the rears having locking hubs. Which axle would be best to drive around on most of the time if I wanted to unlock one? Front rear or rear rear?
4,793
IMHO, I'd go with a air locker in the front. A standard locker + hubs would still mean you need to get out and lock them in and out as needed. If money isn't an object the best would be hubs and an air locker. That way the front axle assembly isn't spinning when you're driving it with the t-case unlocked. I don't see me ever getting a locker in the front of my truck. But I would like hubs on mine to help cut down on the drag.
Dual lockers in the rear isn't going to be fun either... But there's also a company that makes a custom axle that uses a front hub to "unlock" a rear axle.
DUG
73
Mesquite, NV
That's what I was looking at - the hub lock for the back. Which axle would you use them on?
Unforgiven
Las Vegas, NV
By 5 ton air locker do you mean an actual air locking differential such as ARB, or an air actuated disconnect going to an open differential?
wehring
26
Angleton, TX
diff locker
He is talking about the diff lockers. I still have a set of anyone wants them. $4000 for all 3. The axle shafts are 1/4" bigger than stock 5 ton shafts. Factory Rockwell airlockers.
Justin Wehring
979 997 3112
Unforgiven
Las Vegas, NV
wehring, do you have any pics? I assume you are talking about one steer & two rear assemblies, hub to hub including brakes?
How would one rebuild them when necessary? Oversized bearings & air actuator parts might be quite difficult to find for a discontinued 5 ton axle.
