5 Ton M929 Ctis Air leak?
derby
S.E. MI.
Our local Village has a few new toys. One of them is a 929? Dump. I have looked through 900+ pages of the wrong Tm and checked a few threads,no love.
The issue is the truck won't build air. It is leaking air from a pancake looking thing under the truck that has a wire harness connected to it. Near the drive shaft between frame rails. I don't know much about the 900's They know even less.
Any ideas, Operator error?
swbradley1
Modertator
1,607
Dayton, OH
My first suggestion is look in the correct TM.
derby
S.E. MI.
Which TM do I need?
There is a vent on the bottom of this unit about the size if your thumb that faces down. About 8" in diameter round,has alot of air lines and a wire harness with about 6-8 wires pluged in the side.
I can't get a pic until I go back after the Holidays.
Suprman
665
Stratford/Connecticut
Probably the air dryer. If air is leaking from the center, insert finger in hole, push up. If it wont push up, squirt a little wd40 with the truck off or it will spray back at you since air is blowing out. Then try to push up.
derby
S.E. MI.
Uh, I was thinking the same thing........
Thanks for the TM I will dive into it tonight.
Also I prefer Log Cabin,
