TURKEY131
- 0
- 0
- Barnegat, NJ
So how many guys have 5 tons in New Jersey? Just curious. I bought an M931 recently and am going to be getting it on the road soon.
I'm not really sure right now what I am going to do with it. It's big and drives nicely. Makes my M35 look like a pickup truck. I have some items that need be addressed, The windshield frame needs be replaced, and the drivers side fender.What are your plans with your 931?
I've rented a Penske box truck in the past year that was less than 26,000 GVWR, but it had air brakes. Guy that did the rental said I did not need a CDL. I'm a little confused on this.You will also need a CDL class B with air brake endorsement to drive it. If possible I would go with Historic plates much cheaper but you still need a CDL.
Technically you do need an air brake endorsement but it is usually not enforced if the GVW is under 26,000 lbs.I've rented a Penske box truck in the past year that was less than 26,000 GVWR, but it had air brakes. Guy that did the rental said I did not need a CDL. I'm a little confused on this.
