Gunfreak25
- 620
- 113
- Yuma, AZ
I am putting this new HMMWV motor into my GMC soon. I am using the Th400 that is already fitted to the truck and has been used in the truck. The transmission is setup for a rubber mount. For the motor, I really want to make some solid mounts. They are so easy, and I could be done in under a couple hours. Problem is, the opinions on this setup are as varied as ever. Some say it will be fine since the rubber trans mount will provide some flex in the system. Some day the rubber/solid combo will crack the bellhousing. Some say, yada yada.
What do you guys think? It will be be an asphalt queen, light duty grocery getter. Not like i'll be drag racing or anything. I figure vibrations are a non issue, seeing as how the truck weighs over 13,000.
