I have a 6.5 IP that is leaking, was rebuilt motor and appears that the underside of the IP was cracked then welded.
does anyone know if the 6.2 IP or Artic kit 6.2 IP will work on a NA 6.5L motor?
both are mechanical, but with the 6.5 having a bigger piston, not sure if the Arctic IP will work.
They look very similar on the outside, a little difference in housing shape, thats all.
Thanks, Paul
Thanks, Paul
