802a generator
Realyswift
Bahama
Just bought an 802 a generator and have a problem when I put a power load to it it bogs out replaced all fuel filters and can’t figure out why the governor won’t come up in speed to keep up with the power load at 25% anybody have an answer would be grateful or an idea Please help powerless
Scoobyshep
1,469
Florida
Are you slamming the load or slowly adding
Sent from my SM-S908U using Tapatalk
Digger556
608
Denver CO
- Any black goo seeping from the exhaust manifold?
- how is your output power configured? What is your load configuration?
- are you getting black smoke from the exhaust
A) At no load?
B) At part load?
C) when engine bogs?
-is the exhaust smoke an even stream and big pulses?
- how old is the fuel?
- what have you done to you unit since purchase? (Filters, fluids, MOV, etc)
- do you have an alternate way to measure amperage on the output? What is the actual load when it bogs?
Realyswift
Bahama
Very slowly an amp at a time have video get to 25%power usage and hz drops and eng bogs out
A) At no load?
B) At part load?
black smoke coming out from exhaust when boge down all filters have been changed new fuel
Ray70
5,857
West greenwich/RI
If you can verify you are bogging down at only 1500w then you are either severely wet stacked, have a bad cylinder ( possibly injector issue ) or perhaps a governor issue. Based on the black smoke an black goo I would say probably not a governor issue.
I would load it lightly ( 1000w ) and crack open 1 injector at a time and verify the engine stumbles when each cyl. is cracked open.
If it does you may be dealing with severe wet stacking.
