Thanks! I will call him when I get to that point. What is a good way to wire the on switch to the house? The generator is 50 yards or so from the switch location. Do you run dc power from the generator batteries to the switch and back to the generator?Kloppk is correct, contact Peter. Its very easy to installl, like Kloppk's units, after you understand your machine. The items that are referenced as S1, M5 etc are labeled inside your machine next to each item, if that helps.
Are you hooking into an ATS or are you just wanting a push button start so you dont have to go outside?Thanks! I will call him when I get to that point. What is a good way to wire the on switch to the house? The generator is 50 yards or so from the switch location. Do you run dc power from the generator batteries to the switch and back to the generator?
For now just a push button, but may do a ats down the roadAre you hooking into an ATS or are you just wanting a push button start so you dont have to go outside?
I would recommend the attachment. Its a wireless 24v transmittor. Hook it to the 2 wire hookup on the board and then use the remote from inside the house. Ive had one on my personal unit for years and still works perfect.For now just a push button, but may do a ats down the road
Thanks!I would recommend the attachment. Its a wireless 24v transmittor. Hook it to the 2 wire hookup on the board and then use the remote from inside the house. Ive had one on my personal unit for years and still works perfect.
Hi Morrow1,Hello,
I bought a inova remote start kit for my new to me mep 802a. Has anyone posted a how to install for people who can’t read electrical drawings? Thanks!
