Accessory switch power
Bo1
Central Louisiana
I am working on the deuce, and apparently have no voltage going to my accessory switch. A lot of wires were cut before I got the truck, and I cannot find 24 volts anywhere under the dash, other than on the 2 "new wires" attached to the start button that someone ran.Where should the accessory switch be getting its 24 volts from?Also, the truck has not alternator in it, and the wires were cut to it as well. (in case the voltage is coming from one of those)Thanks,Bo
