Crapgame
- 329
- 63
- Navarre, FL
Is there anyway to hook up two LS-671 extension speakers with the CX cables for use as a quasi intercom system in an LMTV?
I have an idea to make a dummy RT-1523E from a cast aluminum faceplate, plus either a neutered RT-1439, TRI faux PRC-117F or ICOM IC 7200 (if can even find one in stock) for external comms.
The comm suite below I'm having trouble identifying everything, some of it may just be filler, not correct real world use. I see the Blue Force Tracker for co-driver, looks like a PRC-117F with donkey dick antenna, then an RT-1439 with power amp and antenna tuner.
