adding air to front with ctis disconnected.
zemmy
New Orleans LA
I am having trouble adding air to my front tires. I have the ctis disconnected and I get nothing when I check it or try to add to it. I know on the rears you go to the inside. What do I do for the fronts?
rtk
442
Lockport N.Y.
Is this a A3 or a 5 ton ? When you removed the air valves , how did you cap the inlet pipe , did you add the schrader valve to the elbow? I am a little confused when you say you add air to the rears on the inside , which makes this a 5 ton maybe . pictures would help . bob k
