Advice from a Deuce mechanic needed
mrgerke81
Raleigh, NC
I have a M35 Deuce and half with the Hercules engine. Recently I had a stuck injector and had it fixed and reinstalled. Truck runs very rough still and smokes. I am getting out of my scope of expertise and looking for a mechanic or shop to look at the problem. I live in the Raleigh NC area. Any advice will help.
Ryanpowell167
Elk city, OK
If the injector hung open, there is a chance that you've melted a piston or scored a cylinder. Second the compression check, if low then inspect valve train and if that's good then your yanking a head.
1,808
Get a no contact infra red temp gun. let it run and start scanning the area of the exhaust manifold at each exhaust port. Find the cold one and start there.
mrgerke81
Raleigh, NC
Okay, here is the latest. I did a compression test today. From front to back(radiator to fire wall)
#1 350psi
#2 0psi
#3 0psi
#4 350psi
#5 350psi
#6 will build to 200psi and leak down to 100psi
looks like the heads must come off. Now to just find the time.
RAYZER
59
sanford/florida
#1 350psi
#2 0psi
#3 0psi
#4 350psi
#5 350psi
Ouch!
May be able to find a good used engine, might be cheaper and easyer.
EWhytsell
Fort Mill, SC
Thats a very good, quick, approach to finding the trouble area of an engine. I'm surprised you don't see it mentioned more often.
