ADVICE NEEDED: Sled Pulling with m923a2
Cole667
N.Huntingdon PA
Hi, I have a 1990 BMY m923a2. I plan to pull it next week at the local fair truck pulls. I will probably pull in the street semi class. My truck is powered by an 8.3 cummins. I have installed 3k rpm governor springs and turned the pump up. Should I pull in low range or high? Should I manually upshift and downshift or let the Alison do its job? Any advice on pulling one of these trucks would be greatly appreciated.
Cole
sweetk30
horseheads,ny 14845
from what I have read the 8.3 cummins don't like more than 1800-2k rpm max of the bottom ends let go .
better recheck your home work . . . .
I could be wrong tho .
Suprman
694
Stratford/Connecticut
Low range put it in drive 1 and push the gas pedal. I don't know how your higher rpms will affect trans shifting. I think when you get to 2500rpms max if you do, you will want to upshift to 2 manually. If your on dirt deflate your tires to around 40psi for better traction. Is it a plate sled or a real puller sled? How much weight do they have? There isn't much out there that will out pull a military truck. Except maybe a bigger military truck.
swbradley1
Modertator
1,705
Dayton, OH
Not much out there that will out pull an MV? Ever been to a pull with 4x4 turbo diesel pickups. They easily out pull an MV.
A few of us went to a pull last year and all had 5-tons. Every diesel pickup out pulled the 5-tons except for one that broke and another didn't make it more than a few feet. No, I didn't pull the 813.
The automatic and TC give up well before the engine loses. Real sled (300 foot clay track) and all but one of the pickups were diesels and that gas truck was right from the show room floor (literally) and it almost did a full pull.
Ford Mechanic
Edenton, NC
I pulled mine last year, I think their sled was a little smaller than some I"ve seen. It was a plate sled, set with as much weight as they had available and all the spikes down. I had no extra weight, tires at 55 psi, low gear, and limited to 1st gear. It was slow at the end but she pulled it past the 320 ft mark. I kept the rpms at 2k until I felt the load finally and the went full throttle, at that point it didn't get over 2200 rpm. When the weight hit the top it slowed me to a crawl and 1500 rpm but it toted it to the end.
Several folks here have done it, and there are a couple threads on it like this one.
http://www.steelsoldiers.com/showth...ith-a-5-ton-(and-a-M920)&highlight=sled++pull
Your over thinking it, find your inner redneck and hook her up!:tank:
Suprman
694
The a2 5 ton with the fuel turned up and in low range 1st gear will pull and not bog like the 250 motor. Once that turbo is spooled it just pulls and pulls.
Jayco36REQS
Orlando/FL
The sled we pulled was at max weight of 60,000lbs, and he dropped the pan at 75 ft.... vs 200 ft normal. Since it was an exhibition pull, and we hadn't pulled the 5-tons before, we had no idea how they would do. So the sled operator and myself agreed to take it on the cautious side and overload things. I made 2 runs... 1st in high range-drive. The 2nd in Low-range drive. In both runs the truck shifted up to 3rd, then back to 2nd... but never down shifted to 1st again. In both hi and lo range, the torque converter let go and ran out of rpm before the motor ran out of power.
My 2 cents.... manually shift it up and down to keep the rpm up, while maintaining the fasted ground speed. When it comes to pulls, momentum is life. Also, if the truck starts to hop? Get out of it. Things will break VERY quick!!
btw.. Does anyone still have the link to the videos of our pull on youtube? I can't seem to find the posts or link anymore!
Suprman
694
I was at full rev around 2200rpms with the pedal down in low range I didnt have any issues with my tq converter. I want to try the M1078 this year.
