Advice--Words of Wisdom?
cjkeeliii
Thomasville, GA
I think my m1008's left rear axle seal is leaking--there is oil coming from the drum. I guess that means I'll be explaining to the wife why I'm spending even more money on my "hobby". So, does anyone have any advice, short cuts, favorite cuss words, etc. for removing the axle and replacing this seal? Any help would be appreciated and might prolong my marriage. :wink:
69dieselfreak
rimrock az
hi guys im new this site but not new to big rigs and vehicles anyway
if you got any sort of oil on your brakes they need to be cleaned with solvent diesel fuel ect after that shoot it down with a bunch of either soak it and then lite it on fire be careful (what this does is brings the enbeaded oil in the friction material up and out ) wont burn for very long and it wont melt anything
make shure that the fire is out shoot it down with some more either let it dry
and then scuff up the brakes with sand paper and away you go
its an easy way to save some moeny if your brakes are still in good condition
wallew
"But dear, it's a hobby. It's not like I'm chasing women or doing drugs or something like that."
And for less than $40 you and a couple of friends (perhaps a case of beer) and you will be good to go.
Changing seals is easy. Brake pads are relatively easy. Even when you don't know what you are doing, read the TM. Problems solved. And you get a feeling of satisfaction knowing YOU did the work.
Chevytruck
Western Maine
dont forget you doing it yourself is cheaper then going to the shop and having them do it! :-D
atankersdad
15
Glen Arm Maryland
Here is what works for me. Buy another one, and tell her its gonna wind up as a parts truck to save you lots of money, or better yet, make you money. After you get to 5 trucks, using this approach, they will lose track of what you have. This is working for me with deuces. "Oh yea, that's a part truck that I will make a fortune on" is my standard replay....
cjkeeliii
Thomasville, GA
OK-Now What?
I have the hub off, and I see a snap ring that appears to be holding the race for the outer wheel bearing. Will this come off/go on easily, and will a set of snap ring pliers do the trick? Will the race just come out if I can get the snap ring off? Thanx.
cjkeeliii
Thomasville, GA
Am I looking too hard for trouble?
Sorry to keep resurrecting this post.
OK, I got the thing reassembled; although I had to clean and grease the outer bearings with them still in the brake drum because I couldn't remove the snap ring. I test drove the truck several times and the hub is warm to the touch , where the other hub is at ambient temperature. Any ideas why? I did everything according to the book. I did put the adjusting nut back tighter than it was when I disassembled it, but I assembled it the way the Haynes book told me: tighten with 50lbs of torque, loosen, tighten by hand, and then tighten until next keyway lines up. When I diassembled the nut it was loose enough to turn with my fingers. I used NLGI # 2 grease. There aren't any unusual sounds, smells, or sights. Is this a mountain out of a mole hill?
GM72K10
68
Bucks County, Pa.
Exactly, besides, if I can buy a "running" parts truck for what I just sold the last "nonrunning" parts truck, how can you defy such great logic for buying another? And it keeps me off the streets, etc.
davo727
Cleveland, TX , Spring , TX
If it gets hot you might just back the nut off one notch
