air assist
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Originally it was regulated, but then they stopped including the regulator.
When mine goes in, I will use an on/off switch. I have heard it causes issues at speed, so I plan on using it only for parking maneuvers.
Thunder in NWOR
Northwest Oregon
Located driver's side frame, by axle - good line drawings in the -386- TMs.
I have put 15,000 miles on my A3, with no air assist problems (have used a little air tool oil).
Mark
m16ty
211
Dickson,TN
It does give a weird loose feeling at speed. A on/off switch is bound to help some but I'm not sure it will completely eliminate the loose feel. From my investigation of the problem, I found that some of it is the air assist trying to "fight" you but some of it is also the amount of slack in the sensor valve. It moves in and out a small amount when it activates which will add some slack in the steering.
Mine isn't installed (I took if off a truck I sold and haven't put it on my other deuce yet) but somebody with one installed could disconnect the air and take it for a spin and see how it does.
