two.fiveM35
- 11
- 38
- Victoria , Texas
The red button on my air powered wiper motor is pushed and and I can not get it out. Any idea on how to get it to come out or am I up the creek and need a new one?
Thanks for the tip, I'll give it a try. I bought a cheap plastic replacement and hooked up a air hose from the shop compressor (80psi) and blew the end off and almost got me in the nuts. **** it hurt.I held my finger over the air outlet and turned the wiper by hand. That popped the button out. Then I replaced it with a metal wiper motor.
Now that is "thinking out of the box !" I'll have to remember that little trick.After cleaning and lubing my old metal units, they worked for a short period of time. They had excessive blow by of the seals. I disassembled them again and found the coiled spring seal expanders were just iron oxide. I replaced the springs with an o-ring of similar cross section. This did the trick. The seals are expanded to the cylinder walls and the blow by is gone. Have not had a failure since. I just need to do the second one to match now.
