Rusty nuts
- 4
- 0
- Oregun
When I got my deuce, the air gauge always only showed 60 psi but everything was working fine. The truck came with a non-military water tank on it and they had used a transfer case air shift switch to open the rear valve on the tank so I had a pressure gauge and plumbed it to the air switch and when opened showed right at 100 psi. So I assumed the original gauge was flawed and ordered a new one. I installed it this weekend along with a new hose and the new gauge still only shows 60 psi while the gauge I have plumbed into the air switch shows 100........any noughts of what is causing this? Is there a better location to tap to check the true pressure? I was thinking the tanks.
