Air pressure sensor under dash leaking
Hooty481
Russell County Kentucky
On my 818 if I shut it off for 20 minutes all of the air bleeds out or at least enough that annoying buzzer comes on to say the pressure is low. I got to feeling around and found the air is leaking from a little hole on the side of the low pressure sensor. Is this suppose to be like this. Is there anything that will fix this other than replacing that piece?
Hammer
398
Winlock, WA
Actually, just pull the thing apart and clean it. That seems to fix it most of the time.
Mine was doing it, and when I pulled it apart to clean, it looked really clean.
I cleaned it anyways, and it hasn't leaked in the three years since.
Hammer
398
Winlock, WA
Mine was really clean. 'If' I remember right, I only used a clean cloth with a little air tool oil (marvel mystery oil.)
