Tony
- 1
- 0
- Camarillo, Calif 93012
How do you check safety valve on the lefthand air tank. Do you depress or pull the small pin, and should it release air when you depress or pull it. The ord part number is 7533854. I'm at the stage of restoration where I have the cargo body off and everything is accessable,and if it is not working I would replace it.
