Air tank fittings
otisroy
Melbourne, FL
My wife's truck has a pinhole in one of the air tanks so I ordered a NOS tank. Got it and hopped under the truck to swap the tank out. I pulled the old tank and sat it on the table next to the new tank. Turns out the new tank is plumbed for way larger fittings at the ends, 3/4" in fact. The draincock threads looks like 3/8" vice the 1/4". Did I get the wrong tank?
If that's the right tank, does anyone have a line on where to get the 3/4" mpt to 3/8" compression elbows? Not a common item at the local hardware store.
1,176
Why not use "reducing bushings", to reduce the opening to the original diameter, then use the original fittings.
ARDUECE
New Site ,AL
let me look tomorrow. i have a bunch of fittings out of deuce air tanks. if i got what you need then u can have it just pay shipping. u need 3/4 npt by 3/8 comp right? u need elbows and tees?
otisroy
Melbourne, FL
Doghead, I thought about it but there's not much clearance on the front side. I have the reducers for the draincock.
ARDEUCE, thanks. I'm 100% sure the pipe threads are 3/4. I'm pretty sure the compression fittings are 3/8. The air lines are 3/8 copper right?
jesusgatos
on the road - in CA right now
That sounds like an air tank out of a 5-ton. I got some of those to use on Mah Deuce, and they've got the big fittings just like yours. I'm using them to store fluids, so I was happy to find tanks with the larger fittings. I'd actually like to get a few more of them.
While we're all talking about tank fittings, one of the tanks I got has a plug in it with a square fitting, but it's not 1/4" or 3/8", More like 5/16", Is that common? Where can I get a tool to remove it?
goodguyzy
13
medford oregon
hey, im a plumber and deal with this stuff all the time, a 3/4 mip x 3/8 comp 90 is pretty common at most ace stores, if not try a plumbing supply house "ferguson" for ie. or a hydraulics supply shop
good luck
