glcaines
- 2,594
- 113
- Hiawassee, Georgia
Does anyone know for certain where the vent line from the top of the power steering reservoir on a FLU419 is supposed to connect? As you can see from the photos, the vent line from the top of the PS reservoir (red arrow) goes up and across the front of the engine and down the other side. At the top of it's travel, the fabric covered tubing connects to a short piece of steel tubing which is connected to what looks like nylon tubing which then dips down the other side and just hangs there. You can also see where the vent line from the timing cover near the hour meter (yellow arrow) is connected and this vent line also just hangs there and is not connected to anything. This vent line is larger ID than the one from the PS reservoir. Are these supposed to be hooked together? I can't see anything in the TMs showing where these are supposed to be connected.
