I delved into the Allison manuals today and came up with some basic info for all Allison Automatic Tranny users.
The earlier 1990's Allison manuals say that Dexron III is suitable for "On Highway"
The suggestion is made for C-4 fluid for "Off Highway"
C-4 #30 Weight is suggested for "Severe Duty" in ambient temps above 95F
Both the DEX III and C-4 carry a 12 month oil change recommendation with filters.
A Volvo truck manual for the MT600 series transmission includes the use of:
#10wt motor oil
#20wt motor oil
#0W20 motor oil
#30wt motor oil
#15-40 Motor oil
The latest Allison bulletins no longer acknowledge Dex III or C-4 since the new full synthetic heavy duty TES-295 oil spec was intoduced.
The Achilles heel of these transmissions is apparently Anti-freeze, or Ethylene Glycol. It will wreck the clutches and the whole tranny. Contamination comes from a faulty heat exchanger leaking into the trans fluid.
Bottom line is these Transmissions will eat just about anything as far as oil is concerned. Allison calls out a "Double Flush" for a fluid type change. Drain and change the filters, fill with oil, drive for 30 minutes, drain, and refill.
The main thing is to use an oil suitable to your useage, change the filters and keep good clean oil in it.
Hope that helps..
#10wt motor oil
#20wt motor oil
#0W20 motor oil
#30wt motor oil
#15-40 Motor oil
Hope that helps..
