altenator ??
roklogan
palmetto GEORGIA
when i start the truck up it used to squeel like lose belt for a few minuets then go away , my thought was loose belt , didnt worry bout it ; now when truck is runing it continuously squeels like loose belt except ........ when i turn the power switch off , truck still runing , the squeeling goes away , power switch back on squeeling starts agian ??? any suggestions ? is altenator going or gone ??
1,177
Check your battery voltage before and after running and switch on. You should be getting 28 running.
Belts new?
You may have a bad battery. Test them recently?
roklogan
palmetto GEORGIA
belts on truck when i bought it from govliquidation , a year ago have nt run it much , slowly fixing it up.......belts are in good shape , may be a little loose . so a bad battery can make the altenator squeel ?
1,177
Sure can. I'd start with new belts.
If you have to crank much to get it started, it is common to have a quick squeel, but none is best.
roklogan
palmetto GEORGIA
it was slow at starting , till today when i changed feul filters and discovered the primary pump was nt running , replaced the fuse in it now fine ; i did spin truck over alot trying to start it till i discovered the problem and thats when now the continuos squeel began ...........
1,177
Try using a 12 volt charger and charging each battery separately, for a day(each) then see how it is doing.
You may have just killed them cranking. In series, they cannot charge 100% properly.
roklogan
palmetto GEORGIA
well i never heard of such , learn something new evewry day , squeeling altenator = possibly low bat's ..cool stuff ...thanks for your help..................rok is actualy my dog's name
1,177
Any thoughts of attending the Ga rally next week?
hilber
S. of Elberton, GA
My CUCV and M35A@ squeal early on-maybe 2 to 5 minutes, I usually let them idle for a couple minutes or so and they don't do it then. It is just when I first crank them if I take on off maybe alittle too quick. . I assumed it was just charging hard from the cranking. Both crank very quick, but the squeal is there most times.
jaymcb
from my working on car (not MV) days, a squealing belt can be caused by loose belts, glazed (worn) belts, or if the load is incredibly high on the alternator, like when a vehicle has a bad or deeply discharged battery or batteries.
