Alternate sounds coming through the air brake buzzer on my M1081.
DTinNC
14
Wake Forest, NC
A few times I have heard some tones etc in addition to the standard wailing of the low air pressure buzzer sound. I'm thinking that this is either by design or corrosion or something through the circuit. Sounds too good to be just a random error though.
I am not currently taking any hallucinogenic substances. 😆
19,750
Any possibility of a loose ground on the buzzer?
Mine makes an incredibly irritating sound, but the tone is reliable .
Ronmar
7,445
Port angeles wa
The troop alarm is the same tone, it is just pulsed... I have heard sonalerts make weird tones when they are receiving reduced current/voltage. Got a wonky connection somewhere? Or the contacts on the air pressure sensors or it’s ground is going bad. I would start there, under the drivers dash(left of the brake pedal), the bracket that holds the two gauge pressure sensors which have the low pressure switch inside them must be well grounded thru that bracket mount... they are screws and screw terminals so maybe something has simply come loose...
DTinNC
14
Wake Forest, NC
Ah! The troop alarm wire was cut off when I got the vehicle. Perhaps the ends are shorting or something. I'll check and reply back when I'm able to peek. Thank you
