Knottofs
- 0
- 0
- White Level, NC
Ok, another idea I want to run past everyone. When I got rid of my other truck, “24 volt” I had a 24-volt to 12-volt converter in it that I kept. The converter will handle up to 25 amps, but only has 10-gage wire coming out of it. Now the winch’s manual says it only uses up to 12 amps max, but use’s 4-gage wire on it. Will that Converter’s wires handle the amperage of the winch? The converter has a 250 volt / 25 amp slow blow fuse on it.
Thanks, Nate
Thanks, Nate
