An interesting comment I heard from deep inside Ukriane
Reworked LMTV
Expedition Campers Limited, LLC
1,173
TN
I have been digging deep into the conflict using Youtube and Foreign news sources, including "France 24" and raw Ukraine rebel footage. I heard that the reason that the first Russian Column failed was that their trucks were shod with fake Michelin XMLs. These tires that had the same tread pattern as the XMLs, BUT were actually faulty Chinese clones and that they had sat too long without using and blew out on a lot of the trucks.
gringeltaube
Staff Member
2,521
Montevideo/Uruguay
..... their trucks were shod with fake Michelin XMLs. These tires that had the same tread pattern as the XMLs, BUT were actually faulty Chinese clones.....
AFAIK Michelin's XML tires have not be cloned yet. But Triangle (which may be the largest tire manufacturer in China) does make the TRY66, which could be considered a XZL clone.
The picture below shows one Russian truck (Pantsir-S1) stuck somewhere in the Ukrainian mud, after both rear tires blew out.
One can clearly recognise the XZL pattern, but we can only assume that those are the Chinese tires.
Just a few days ago I got a bunch of used 95% 365/85R20s from a customer, to be mounted on 12-bolt MRAP steel wheels. Among them were a few of the Chinese (XZL) clones - which he hadn't noticed at the time of purchase (!)
So far, the only real problem is the actual size difference: Once inflated the XZL stands one inch taller and its tread is one inch wider compared to the Chinese counterpart. (talk about "fair" competition...:|)
Guyfang
23,934
Burgkunstadt, Germany
This is a picture of the Pantsir S1 ( SA-22 Greyhound) Air Defence System. It has, as far as I can see a Phase array Radar on it. The great limitation to the much vaunted PATRIOT radar, (Phase Array) is that the radar can only Look in one direction. So the Russians put TWO radars on the radar pedestal, so not they can "Look" in a 360 Radius. Look this baby up in Wiki. It cost about 14 million bucks. Read stats on it. Fires on the move and has 30mm cannons AND Missiles. Bad Motor Scooter. And that is a Ukrainian standing next to it. Why are we not seeing this on the boob tube?
Reworked LMTV
1,173
TN
View attachment 860771 View attachment 860772 View attachment 860773
Interesting info. share. Thank you!
Guyfang
23,934
For the same reason snipers have spotters, most AA systems have 2 radars, search and tracking
Of course. But not all. This Russian system has two L band radars and two Phase Array radars. The Phase Array can act as both. Just like Patriot. Only one radar to the system. But, it only covers 180 degrees of the surrounding area. Thats why the Russians mounted two Phase Array radar back to back in this system.
In Hawk, we had 4 radars. Three accusation, One tracking.
