Another Bobbed Deuce
KsM715
142
St George Ks
I ask because I bolted mine on using all the rivet holes left over from removing the bogey set up and I'm debating wether or not to go thru the trouble of adding flitch plates as well.
blackxj
arkansas
Its hard to tell, is that a 105 frame under the stock frame? If so how did you connect it?
It is the a3 frame with the over loads, a3 frame is wider than deuce frame. Very good contact surface to weld. It is also bolted. I really like the recessed tail lights in the a3 bed and also the fold down ladder.
