brazengoat06
- 2
- 16
- Tulsa, OK
Sooooooooo here it is......
tires aired up to 60psi to start with. i turn ignition on, truck builds to 120, runs pressure check, then gives me 4 flashing lights and the Left Front Tire bleeds off through the front vent down to about 35 psi. i have more than one issue but the issue im trying to diag first is why the wheel valve isnt isolating after the pressure check. unless i misunderstand how the wheel valve works, then im confused by this. ive replace the valve and furthermore swapped positions with a good valve from another wheel and same thing. am i missing something?
