another newbie
k1hb
boston/ma
a5 model.
its quite grimey. how in spring should i scrub it? its desert yellow.
where should i put the battery?
i think i am going to weld a towbar mysel to pull it behind my 404 unimog....or does anybody have a spare one for sale?
fun machine.
hope to pull the kids on skis at xmas, or on sleds...no chains and original tires though!
hndrsonj
Senior Chief/Moderator
365
Cheyenne, WY
Pull the bed off and pressure wash. May as well paint while you are at it. Look at Mechanical Mules Of America for the battery box and location. I'd be careful towing, don't know the max speed. I always hauled mine.
majorhitt
Dallas Pa.
I have a Mule on it's way from Dave. The bed is in OK shape. hndrsonj says Pull the bed off and pressure wash it. Being that I don't have the Mule as of yet, How many bolts hold the deck to the frame? It has a few small holes that need to be welded closed. Aluminum deck. I do have to get the TM's sometime.
asgtoolman
Florence SC
To all newbies; get to know Bill Watson, Dave Kelone and Mechanical Mules!!!! All are great resources. IMO Bill has more original or NOS parts, MM has good fabricated parts [battery boxes, foot baskets] and Dave has some of all.
I not sure about towing, but think 20-25 mph would be TOPS and only for short runs! Not supposed to tow in 4 wheel steer if I remember correctly.
SERIOUSLY look into converting your A5 to 4 wheel steer; makes ALL the difference!!![Bill Watson has the kits] - takes a day to do it if you have any mechanical skills at all.
Unless you are going to do a MAJOR rework, I'd leave the bed on and do a super pressure wash job. The bed does not just unbolt from the frame, several assemblies are all tied together with the bed. I took mine completely apart and sand blasted, primed and painted and then reassembled, but it was a little tedious as I do 99% of my work by myself.
