bbf
- 0
- 16
- port st lucie fl
pick this up a few months ago and finally got the tow bar on the trailer
I believe you'll find the trailer's driveshaft will not hook up unless he replaced the truck's rear axle, they don't have an output rearward. Only axles 2 and 3 have power dividers and outputs. Even then, the axles might have a different gear ratio.Can you post up a couple pictures of ho the trailers drive shaft hooks up as well as how the trailer hooks up? Thanks.
Spelling the acronym correctly would probably help you in your search...that and a big wad of cash.How is everyone finding and getting hemmts
Go get the MK48. You and paradeduty would have quite the combined fleet.at the time i pickup the traileri did not know much about the hemtt and later to fine out that trailer is for a mk 48 power head so had to take out d/s
I'd like to have a MK48 too....Go get the MK48. You and paradeduty would have quite the combined fleet.
Is that the 983 tractor that another member had that needed a motor when he got it from gsa
Yup, that's why I've decided to sell my MK17. I really can't bring myself to hacking up such a nice unit.I can't have nothin!!!!!!!!!!!!!!
Ted's Trucks and Stuff in Dothan, AL has the cab for that trailer but you better wear your britches with the big pockets.
