Antenna Broke on a tree
marylandgrdnr
frederick, md
No pic in this post but i wanted to reach out and see if there's a source for antenna pieces. I broke the connection on the top piece backing out of a driveway...(antenna tied down in rear) The lower piece and the mount seem to be ok.
thanks for the help
T. Highway
53
S.E. WI & S.E. TN, USA - Earth
It would help if you knew which antenna you have, there are many different model numbers.
There should be a label just above the base of the top section, if not there should be a label on the bottom section. If no labels are visible, you could measure the overall length and use the antenna base model number to figure out which top you need.
Bert
Gripy
Los Angeles, CA
shove a wooden rod into the hole and paint to match. Maybe some bondo and sand it so the transition looks nice.
Since all you're going for is looks.
