Does anyone know what type of aircraft this FM antenna was mounted on. It is very similar (probably a later generation) of the FM whip antennas that were used on the O-1 and O-2 in Vietnam. The antenna is built a little stouter and measures 55.5 inches from tip to tip and tapers from 1/2 inch at the base to 1/4 inch at the tip.
The machined aluminum base weighs .7 lbs and is 5.75" long and 3.75" wide. I have been unable to determine what the aircraft application was and could use some help with the ID.
Thanks Guys,
Steve
Thanks Guys,
Steve
