Antenna questions
iasc399ia
iowa
I own 1986 M1009. It has one side antenna bracket with some sort of piece in it that currently has a cb antenna hooked up to it.
Today I acquired two antennas the guy called "whip" antennas. These are the same antennas I have seen on humvees. I also got a bracket from the guy, but I do not know what sort of device goes into the bracket to screw the antenna too.
Any help is appreciated
Also with the new setup will I still be able to run my cb on it or would it be to powerful?
I also want to add another setup on the other side, just for looks.
Thanks for the guidance in advance.
Warthog
231
OKC, OK
Do not use the word HELP in your titles unless your life is in danger of you are stuck on the side of the road.
On this site we help with everything and take the HELP call serious.
Also make your titles meaning full. When you get you question answered a meaningful title will help the next guy find the thread that relates to the same question.
NDT
6,346
Camp Wood/LC, TX
Looks like you need MX-6707 bases for your masts. The loose bracket is for HMMWV.
ZiggyO
437
Nebraska
Actually he may need as3900 bases which have a larger diameter thread than the mx6707........ look closely, they appear to be later style whips........
Z
M813rc
3,069
Near Austin, Texas
The visual differences between the AS3900 base and the MX-6707 can be seen in the attached photos.
Since you are going for looks only, it wouldn't matter which one you used EXCEPT that you have whips that fit the AS3900 base only.
The threaded part above the base spring, (under the cap pointed to by the yellow arrow) is a slightly different diameter between the two, thus the threaded bases of the whip, that big black nut-looking part, are different.
Cheers
iasc399ia
iowa
Its all good, I appreciate the information though!
Got the bases in and all installed. Still need 1 aluminum antenna brush guard though.
