350TacoZilla
- 0
- 16
- Hancock MD
I'm just wondering if anyone knows what would happen if you get pulled over hauling something in bed of a bobbed 5 ton, they look at data plate and it shows 3 axles where you have 2 what do you think they would do about the weight ratings? Also where does the gov get 31600 total weight when loaded? If you add the unloaded weights up it equals the total weight if you add the loaded's up it comes up 10K over. I do not plan to haul 10K in the bed of truck but just wondering if that data plate showing a 6x6 truck is going to cause problems. I remember seeing someone had made a "bobbed" data plate for the deuce crowd, maybe I should do something similar?
