springer1981
- 1,150
- 93
- Maine
I have an essentially new Vic-3 Lite system with new Bose headset and out of the box it has some issue. Note all cables except 1 headset cable are new.
The Vic-3 Lite controller seems to function 100% and don't suspect any issue there.
The Crew Station seems to function correctly in the Intercom settings. But here is what it happening in other settings.
1, The left side i'll call the Driver Side can be switched to any position and there is no difference in headset sound.
2, The Passenger side makes a tone in C, D, E or F position. Then also makes a tone when switching back in position B and A intermittently. It doesn't seem to make the tone when switching past them the first time. The Driver side doesn't do any of this.
3, Tried ever combination of headset and headset cables and it doesn't effect the tone.
4, The tone isn't technically a problem in that I have no radios and no intention of using those setting, it will always be in INT mode but is offered for informational purposes since I am not sure exactly what is expected operation.
5, Both headset (brand new) had lots of scratchy and staticy noise intermittently but I don't seem to be able to associate to a bad connection at the headset wires and connectors. Again, it doesn't matter what combination of cables, headsets or driver side vs passenger side ports I use.
6, 1 headset has no sound in 1 ear. Again, doesn't matter the combination of parts.
Based on the above, I know 1 headset has an issue with 1 ear speaker or something. Both headsets seem to work with voice communication but static and scratchy issue effects being able to hear the other set intermittently. I have reseated all cables and swapped cable with no change. I have banged on the crew station with a rubber mallet and that doesn't affect the static and scratchy sound. I've wiggled and played with the wires but can't isolate anything that consistently affects the sound.
I'm leaning toward both headset having problems but Brand new sealed and just opened?
Any suggestions based on experience would be greatly appreciated. Thanks
