mudguppy
- 15
- 0
- duncan, sc
First off, this install isn't going in my MV - it is going in a project truck, but I thought others may benefit from a couple things I have learned.
Secondly, the truck is nowhere near complete yet, so I will not be able to give any driving impressions. However, having lockers in my truck, I can assume that 'locked' is equally impressive, but the 'unlocked' is much more street friendly than the auto-lockers.
The install:
The ARBs are pricey - I picked up 2 lockers and an air compressor from East Coast Gear Supply online. They were priced competitively, had good reviews, and shipped relatively quickly. The ARBs were packaged well and included everything needed for the ARB system: locker, air lines, solenoids, switches, fittings, etc.
Dissassembly of the differential is pretty straight-forward. I picked up a few tips from SewerZuk's thread as well as SpicerGear's tip about using washers/coins between the diff housing nuts and diff housing to break the seal to the axle housing - that was a great tip!!!
Further dissassembly of the differential was also straight forward. The bearing caps, however, did take a lot more motivation than my 1/2" air impact could supply. If you don't have a larger impact, this can get tricky because the differential is extremely awkward to stabilize and work with. I ended up standing on the upside-down diff and using a breaker bar and several sledge hammer hits to break the bearing cap bolts free. That was tough.
Also tough was the actual differential carrier bolts. However, once apart, a good whack with a mallet freed the carrier halves and gear.
The pics below show one of the ARB boxes opened up; axles that I'm working on; dissassembly pics; differential pics; differential dissassembly.
The install:
