As close to a 4-door CUCV as I can get
Tornadogt
Adkins, Texas
I found this Criagslist and had to join the "little truck club" :-D
It is a 1990 3x3 4 door
6.2
400 trans
205 Transfer case
4.56 gears
Traction lock rear
Title states it as 1 1/2 ton
The Rear end is standard Dually width not Cab/chassis width.
It is Military and has the data tags. I was told it was a fire truck for the military before being used by the local Fire department.
Plans are to install a standard CUCV core support/grill and brush guard. MRAP seat set 2 buckets up front and 3 in the back, Lift it enough for HMMWV wheels and tires, and a fresh 383 CARDC green paint job. (maybe camo)
I am unsure at the moment about the bed, Keep it, go with a standard long bed, M101, M1101??? any of them are possible.
Photos
1,808
Something to measure before settling on a bed. I know you said it had the wider rear axle from a dually type pickup not a CC axle. I would still measure the cab to axle length to confirm it. There was a cc with the wider rear axle. It was referred to an ambulance chassis. 56" cab to axle is a pickup, 60" CA is a cab chassis. As far as trailer beds, I hope someday someone does one right and moves the floor of the bed up. In my opinion they look kind of funny with the bed so much higher than the cab.
Tornadogt
Adkins, Texas
I will check that out and post back.
Gottlos
Former 95B Ft Sam Houston
Canyon Country, CA.
It seems that Texas is the Mecca for trucks. That truck would have long ago been recycled into a Hyundai or a Chinese toaster out here in California. You sure have the makings for a sweet CUCV.
Tornadogt
Adkins, Texas
Took a measuring tape to the truck today, back of the cab to the axle is 56". Also spring length is 56" on the rear (helpful info for the lift kit later).
Tornadogt
Adkins, Texas
I was able to pick up a donor truck for my project.. It is a 95 Dodge Gen2 5.9 12Valve Cummins, NV4500 5-speed Standard 2wd. I have already gotten the GM tail-shaft housing and ordered the GM transmission output shaft to mate it to the 205 transfer case. By getting the complete truck I plan on also using the Radiator, Inner cooler, AC system, and hydraulic clutch pedal. Some other useful parts maybe the engine crossmember and Dash cluster. One step at a time.
