For those that won trucks at Ft Sill on the 25th......
You may have won running trucks, but DO NOT plan on it for your recovery.
Have backup plans in place.
While the GL ladies are extremely helpful, there are issues.
The trucks are not at the GL yard, they are at a base storage/maintenace yard and the yard supervisor doe NOT allow any inspections/preview/repairs. He is strick on this issue. Also no working on them, fluid checks only. If it does run you are allowed to drive it off base.
You make an appointment and you better be there. 15 minutes late and you have to reschedule. Base rules, not GLs.
No load out assistance, no loading dock and usually only 30 minutes to get in and out. GL escort required.
One good thing is the trucks are local and the fluids are usually still there.
So to summerize: Plan on towing out, have someone pull it offsite or if shipping, a truck with a detachable trailer and winch.
Out of the three trucks I have picked up there, two where runners with a little help and one needed a new tranny. All where towed off.
