coyote62ny
- -1
- 0
- sherburne new york
i have a mep-003 when in the prime aux run position on the master switch should the auxillary fuel pump run when the fuel tank is full as i understand how this system works is that the float switch does not control the pump but controls the silonoid valve on the auxillary fuel pump to allow fuel to pass to the tank. on my mep-003 the auxillary fuel pump runs with the tank full when in the prime auxillary run position is this normal thanks in advance for your help.
