baxter
- 4
- 0
- salt lake, UT
I installed my winch and pto last weekend and was wondering how you guys are checking the backlash on the pto.I was not able to get the dial indicator in.
Vaughn
Vaughn
I'm about to give this a shot. Visually, you're looking for "a little bit" of play? Not sloppy but not firmly against, either?Totally agree with Dan!
And if you don't want to pull that nicely sealed PTO inspection cover or even open the tranny's top cover... there is a little trick that always worked well for me: one can actually see both gears (reverse idler and PTO input) and how much play there is, if a (AAA) mini- or a AA-Maglite (with lens head removed) is introduced an inch or so into the oil level inspection hole, then look trough the oil drain hole while rocking engaged PTO back and forth at the output flange.
G.
