Backup camera and radio rack stuff
papakb
1,185
San Jose, Ca
GPS trip computer zerod.jpgPRC-138 in Harris single mount (1).JPGOne of the first things I did when I got my truck was to install a backup camera because of the poor rearward visibility. I originally mounted the camera in the ambulance body but everyone wants to touch it so I relocated it down on the "D" Beam where it's out of sight. The image I get is perfect, the lump in the center is my pintle hoop which makes it reallu east when backing up to hookup the trailer. There's also a perfect hole right in the center of the beam to moount the camera in.
I wanted to combine things to keep the dash clear so I bought an old Garmin Streetpilot 7200 because it has a 7" display and an external video input so I can use it as a GPS, a backup camera, or a trip computer. I find that on sunny days glancing down at the speedometer only gives me a black hole while the Streetpilot gives me everything I want to know on the road. Mounted where it is on the "A" beam it doesn't block the road and I barely have to take my eyes off the road to read it.
I had a single mount SINCGARS set in the truck that I'd used for a couple of years and when I got my PRC-138 I modified the battery box so that it now clamps right into the same mount as the PRC-119. Now I can run either set and the only thing that I need to change is the antenna.
Original backup camera
"D" Beam camera
Streetpilot camera
G3isMe
Texas
It looks great. I had to mount my camera under the beam for clearance. I was worried about road crudd on the lense but so far that has not been an issue.
