Bad Oil Pressure Gauge
ApolloKnight
Tampa
So while cleaning up the generator this past weekend after an oil change I noticed the oil pressure gauge doesn't work. I tapped it a few times, but the needle appears to be frozen in the 0 position. The motor doesn't shut off, so I think the gauge is bad.
Is there an easy way to replace this with an off the shelf unit, or should I try to find an OEM?
jamawieb
541
Ripley/TN
I've read several post that people have used the Beede 12803 but I have personally never replaced it with one.
Bmxenbrett
30
Its not a mechanical gauge so make sure you get a sender with it if you go aftermarket. Or at least know the Ohm readings are compatible.
I have an aftermarket fuel gauge and used the original sender.
DieselAddict
1,957
Efland, NC
He wasn't specific in his post but he has a MEP003 which has a mechanical oil pressure gauge.
pjwest03
37
Vestal/NY
For mechanical gauges, I like Hewitt Industries. They look the part and are available with 24v illumination as well. Their prices are pretty reasonable.
