If you plan to install a disconnect, keep it under the hood. Use a marine rated switch such as the Blue Sea Systems 9003E. The 9003E is rated for 350 Amps and is designed as a disconnect for use with diesel engines. The #3000 model is rated for 500-600amps if you wanted something heavier.
I can think of several reasons why someone would want this on a cucv. The first time your starter relay or solenoid sticks on you will wish you had one.
All the naysayers here have silly reasons why they think it is a bad idea. "tight" connections? Depends what monkey worked on the truck last. "weird" things?
Regardless if the truck is 12/24 stock; when you switch the chassis and main ground from the battery pack ( front battery NEG ) you have the ability to control 12v and 24v with one simple switch. If the ground is interrupted, there is no power...period.
***Just make sure you run BOTH black wires, the chassis ground (small black wire) and the main NEG (big black wire), to one side of the switch and the other side to the NEG of the front battery. If you don't and you try to start the truck, then you will certainly fry your fuse-able links and that chassis ground (small black) wire.
Be smart, use heavy gauge wire, check and triple check, and you will be fine. I had a starter run on problem I was trying to isolate and installing a cut off switch allowed me to change out components until ultimately finding the cause. Turned out it was a bad starter solenoid.
