Better trans internals?
Dixon77
87
Ohio
I did some searching and came up with a mixed bag of info
I've got a '72 M109 that seems to have a 4th gear that didn't play well with the others. It would grind a little shifting into it over 1500rpms and progressively got to where it just gave up
It must be contagious because my Xterra developed a trans issue too so they are both down.
I'm pulling the Deuce trans here soon to have my trans guy go over it. So, is there any manufacturers that make rebuild kits or stronger (hardened or cryo treated) gears for these Spicer trans?
I'm still daily'ng the Deuce till my Nissan is fixed without 4th so it'll be a while but I'd like to order the stuff now.
Thanks!
rustystud
2,977
Woodinville, Washington
Thanks!
No one manufactured any "special" parts for the Spicer 3052/3053 transmission. You can send the gears out yourself and have them "Nitrided" and or "Cryo" dipped. If you do go this route, I would buy new gears to do it to.
